Hey,
Computer specs
Intel Core i7 920
Asus P6T Deluxe motherboard
Gskills 1.5v 1600 mhz DDR3 memory
ATI Radeon 4870X2
Zalman 850 watt Dual Heatpipe cooled Power supply
Anyway, issue at hand is the 8 pin cpu/motherboard connector. My manual says it requires a 4/8 pin EATX 12v power supply connector. My power supply connector only produces 8 pin EPS 12v connector.
The 8 pin EPS 12v connector is split into 2 4 pin connectors, one complying with a 4 pin EATX 12v power connector. Plugged in, boots etc.
Just wanting to know is there anyway to get a 8 pin EATX 12v power connector, like any adapters or anything, because I plan to overclock pretty heavily, i just misjudged this part.
Thank you.
(I need to buy an extension cable for it because i modded my heatsink fans and now the 4 pin part of the EPS connector can't reach >.> so may as well kill 2 birds with one stone).
Computer specs
Intel Core i7 920
ATI Radeon 4870X2
Thank you.
