Question 80 FPS On All Low With 2700x 2070 Super On Ultra Low Settings
Swiizy
66
I have a 2700x and a 2070 Super and I'm struggling to get 100 FPS on ultra low settings. I used to get 120+ on all high.
Isn’t user benchmark inaccurate? Many people have told me that it’s not that accurate.
Not REPRESENTATIVE due to the large number of overclocked results and scoring being skewed toward single-threaded performance when most current software can use 2-4 cores is not the same thing as inaccurate.
Still useful to determine which component(s) might be grossly under-performing expectations.
Reactions: drivinfast247
Looks like your CPU is under-performing by a pretty significant margin for some reason. If temperatures are ok and you haven't changed anything to your hardware since getting 120fps, you could try keeping an eye on per-core boost frequency. Maybe the CPU isn't boosting like it should.
I'll see how that all is next time I get on a game.
On idle all cores are at 3.966 and in game its 3.941
For GPU I did FurMark at 1920x1080 and I got 0 crashes and was at about 65-70 degrees and utilization was at 90-95% and for CPU I used IntelBurnTest and was sitting at 100% utilization and around 70-75 degrees with no crashes
Ok, well that is a good sign that it is an issue within the game. Maybe try a clean install of your drivers. Also double check your video settings. Look for render resolution and make sure it is set to 100%. I have issues where modern ware will reset my video settings.
The render resolution is always on 100%
