80mm Fans for front of case?
illegalrugalah
139
I need 2 80mm fans for the front of my case... could someone suggest good fans for a low price?? (doesnt need to be that quiet, but not too loud. LED not necessary but if its cheap 😀 anyways, how should i set up my push pull system??
i have one on the back pushing air out and one on the side pushing air in. should i make the 2 front fans intake?
this is my case: http://www.newegg.com/Product/Product.aspx?item=N82E16811144123
my build is a 970xtreme3 mobo with a radeon 5770, amd fx 4100 @ 3.6ghz and 8 gb ram
