I overclocked my 9700k to 4.8ghz with the CPU voltage set to 1.335 volts and I tried to set it to 4.9ghz to see if it would run and it seemed to run fine with temps no hotter than 84 degrees but it immediately crashed when I tried to run a test with avx2 enabled. After this I reset the OC back to 4.8ghz and it is now crashing with avx2 enabled when I don't believe it was before, I'm using the Intel extreme tuning untility to do this btw. Can someone tell me how to fix or what applications use avx2??
