hftvhftv Distinguished Ambassador May 26, 2014 966 148 19,390 Jul 24, 2019 #1 This is the first graphics card I've bought with a 0RPM fan mode below 60C, but I can't hear the GPU fans over my case fans unless it's above 75%. Should I probably set a custom fan curve to make the fans run?
ThatVietGuy Titan Nov 6, 2007 11,718 314 70,240 Jul 24, 2019 #2 How are your idle temps? You don't necessarily have to set any custom curves unless you want to run cooler at idle. Upvote 0 Downvote
Metal Messiah. Judicious Mar 28, 2019 7,511 2,245 32,740 Jul 24, 2019 #3 Which GPU Model/brand is it actually ? Who is the manufacturer ? You mean to say 75% Fan speed, or the Temp value ? Upvote 0 Downvote
