A couple of weeks ago I installed a SapphireTek 9800 Pro 128Mb in my computer, and this morning I removed it to get the S/N and P/N for registration, when I noticed that the heatsink gave in while I was pulling on it! Of course, the down-force from the spring pushed it right back into place, but I'm a little bit concerned here...
Basically what's wrong, it appears, is that the heatsink does not have enough thermal compound, or the thermal compound simply hasn't hardened yet. It's bad though- when I lightly push on one side of the heat sink, the other end rocks upward, and I can see into the core and all of the paste oozing everywhere, so there's no way that there is a solid seal inside there when the springs push it back down. I should remove it and re-seat it properly, which I have done with my Ti4200, unless someone has another suggestion. I have Arctic Silver Thermal compound, and I was wondering if that was appropriate to use as an alternative to the white silicone crap that everybody supplies with their heatsinks.
<P ID="edit"><FONT SIZE=-1><EM>Edited by sweatlaserxp on 03/19/04 12:12 PM.</EM></FONT></P>
