Good morning guys, I've attempted to manually oc my 9900k to 5.0ghz following one of the multiple guides you can find online. I'm using a z390 aorus pro as a mobo and a noctua nh-d15s for the cpu cooling. After several failed attempts even at high voltages, I found out stability with vcore at 1.35, vccio set at 1.20 and vcssa at 1.25 (probably the xmp profile was causing instability and not the vcore).
Now during timespy even with a fixed voltage I can see the vcore in the osd raising from 1.35 to 1.38. How is possible that the vcore would rise like in auto mode? My timespy cpu score also looks low compared to the average (got 11460). Temps during cpu test are around 85 degrees ( a bit too high with that cooler right?). That's all for now, hope i was clear and can get an advice on what I'm getting wrong here. Thank you
