I have a long house (a farm) and another building next to it.
From one part of the house to the other, i have a network cable under the ground that goes to the other end.
When I connect Devolo´s Dlan1200+ everywhere, then the further I go from the modem, the worse the connection is. In the other building, the speeds drop a lot. +- 15 megabit left (not trustworthy).
The connection comes and goes all the time.
Is it possible to give the Devolo´s on the far edge a connection with the existing LAN port, so that it acts like a bridge so the connection is good there as well?
I tried it of course, but it doesnt work. The speeds do not change. Any way to fix this the way I thought?
Thank you in advance for any answer
