G
Guest
Guest
Archived from groups: alt.comp.hardware.pc-homebuilt (More info?)
AMD K6-2 500mhz
160MB Ram
10 gig HD
Matshita CD-Rom
Turtle Beach Sound Card
ATI Rage Pro agp video card
Zoom 56k PCI Fax Modem
On Board USB
J-Bond PCI500C-Pa Motherboard
USB Keyboard and serial mouse
I built this system as my personal system because I have difficulty
sitting at the family PC. This one is at a more comfortable chair. All
of the parts listed except the Keyboard and mouse were free and gathered
over time. I was wondering a couple of things and was hoping someone may
have an answer.
1. Sometimes when I reboot or turn on the system it detects the cdrom
and instead of finishing the boot process, reboots and starts over again
in a endless loop unless I hold the reset switch or power off. However
it is random and I can't make it do it. Windows never has a chance to
load. I have changed the cdrom and it has had no effect, plus this has
happened with no pci cards and with different ones. The only thing I
have had steady problems with is the AT keyboard connector will not
work. (fried). Tried to make a AT to ps2 converter. Not smart, but I did
it. Then got smart and got a USB keyboard. Unless its the damage done to
the Keyboard port I am at a loss. But as I recall it did do this before
the At connector was ruined. So any help is appreciated.
2. I have the 160MB of ram installed. I know that 2 of the 3 sticks
installed is pc100 but am unsure of the 3rd.I have the FSB set at 100mhz
and have had no problems running Windows. No crashing and I have run
memtest 3 times for a total of a little over 5 hours with no errors. I
was just wondering if I should worry about the 3rd stick. Doesn't seem
like I should, but I always like another opinion.
Thanks for any help in advance.
TigerHawk
AMD K6-2 500mhz
160MB Ram
10 gig HD
Matshita CD-Rom
On Board USB
have an answer.
TigerHawk
