[SOLVED] A Power cut happened when my PC is running, is it okay?
fathan1805
19
There's a Power Cut happened not long ago, before it come back on i unplug all of my PC cable, i dont know if it make a diffrence especially since i heard a lot about those Power Surge and im still worried about it.
My System works fine but i dont know about the long term
Oussebon
Upstanding
Feb 17, 2020
269
50
240
6
It's almost certainly fine. If it's behaving normally, I wouldn't worry.
If every PC died every time there was a power outage, people wouldn't use PCs.
If you get frequent power cuts you could look into a UPS (uninterruptible power supply).
But as a one off and if your system is working fine, it sounds like you're alright :)
Reactions: fathan1805
Oussebon
Upstanding
Feb 17, 2020
269
50
240
6
fathan1805
19
Alright thank you very much.
Reactions: Oussebon
