A queer problem - PC is shutting down
G
Guest
Guest
Archived from groups: microsoft.public.windowsxp.general,microsoft.public.windowsxp.hardware,microsoft.public.windowsxp.help_and_support (More info?)
Hello,
I’m having a queer problem, my PC (IBM Netvista M50) is shutting down every
few minutes with no special reason. I’m running XP with all the latest
service packs and updates. After I restart the PC, there is no event in the
event logs and no hardware error.
Any Idea?
Thanks
Janiv.
You have a virus
run an up to date virus checker.
"Janiv Ratson" <janiv@aoe6.net> wrote in message news:euDxxOVbEHA.596@TK2MSFTNGP11.phx.gbl...
> Hello,
> Any Idea?
> Thanks
> Janiv.
Virus scan ur computer. This is probably a virus. If you can't keep the computer alive during the scan, you need to find a bootable virus scanner and go from there.
"Janiv Ratson" wrote:
> Hello,
> Any Idea?
> Thanks
> Janiv.
Most likely a virus, then hardware fault (powersupply or memory or other).
Hope this is useful to you. Let us know.
rms
Janiv Ratson wrote:
> Hello,
> Any Idea?
> Thanks
> Janiv.
Greetings --
Make sure that all of your cooling fans are working properly, that
the PC's interior is free of dust, and that all of the PC's case's
airways are free of obstruction. You may well be overheating; if it
goes on too long, permanent damage to the CPU and of chips may occur.
Bruce Chambers
Help us help you:
http://dts-l.org/goodpost.htm
http://www.catb.org/~esr/faqs/smart-questions.html
You can have peace. Or you can have freedom. Don't ever count on
having both at once. - RAH
> Hello,
> I'm having a queer problem, my PC (IBM Netvista M50) is shutting
down every
> few minutes with no special reason. I'm running XP with all the
latest
in the
> Any Idea?
> Thanks
> Janiv.
Also, try setting your system clock back to the right time :)
Try Safe Mode and see if it reboots from that too. Press F8 before
Windows loads (just after the POST screen).
Nathan McNulty
> rms
> Janiv Ratson wrote:
>> Hello,
>> every
>> in the
>> Any Idea?
>> Thanks
>> Janiv.
