Question A10 cpu temps
The one where you see the thermometer next to CPU.
For those voltages, your temps look about right. To add, if you had an aftermarket cooler, that temp range will be a little better. At a glance, your voltages seem to be high. Mind sharing your ram's make and model as well? You're going to get the best out of that APU if you go for DDR3-2133MHz or DDR3-2400MHz in dual channel.
There is thermometer to all 3 cpu listings xD. Do i look the one from MB?
The cpu voltages are default ones. And i have heard this cpu is nice to oc.
RAM is single stick 8GB DDR3 Kingston HyperX Savage 2133Mhz. I have already enabled XMP (DOCP) to go from 1600Mhz to 2133Mhz.
Thanks for the answer btw.
