G
Guest
Guest
My system is as follows:
A7V V1.02
Bios 1004d
Promise Build 33
Windows 98SE
NVidia TNT2 M64
Maxtor ATA100 7200RPM 30G
SB128
Enlight 300W Case
CPU temp Maximum 52 degrees.
I just put it together and it's working great. The only problem I'm having is moving my hard disk from the primary IDE to the ATA100. When I do this, the hard disk is correctly regognized by the ATA Bios (yeah), but then fails boot with the following error message.
TrendChipAwayVirus has detected a boot virus on your hard disk.
Press <enter> for more information
Press <c> to continue
This message is in a red square with yellow lettering. Continuing gets you nowhere. I disabled boot virus in the bios (knowing it wouldn't help) and it didn't help. I just formatted this hard disk and I ran Norton and PC Cillin virus scan to make sure. I'm convinced this disk does not have a virus.
My next step for lack of a better idea is to load Promise Build 25 since I've read that it might be more stable. I haven't read anything that would suggest this is a Bios issue. Has anybody out there seen this error before? Could this be a compatibility issue with Maxtor?
Any help is appreciated.
A7V V1.02
Bios 1004d
Promise Build 33
Windows 98SE
NVidia TNT2 M64
SB128
Enlight 300W Case
