A7V600 and front panel audio
G
Guest
Guest
Archived from groups: alt.comp.periphs.mainboard.asus (More info?)
Hi!
I have Asus A7V600 and I meet a problem with front panel audio. I wanted
to connect front panel of my casing. I have 5 cables out of my casing
for it: white - EAR R, black - GND, green - EAR L, black - GND and
yellow - MIC IN. Along the manual I had to remove jumpers. So
I connected it like that:
yellow--->MIC2
black---->AGND
white---->Line_out_R
green---->Line_out_L
but in this configuration I have no sound from my speaker connected to
back panel. What's more: microphone works only when connected to front
panel but not to back.
So please help me how to connect it to be able to use
speakers connected to back panel and headphones with mic connected to
front panel.
Best regards.
tomjas
[ tomjas@WYTNIJTOpoczta.onet.pl ] [ GG# 4513130 ]
[ Registered Linux User# 309932 ] [ICQ# nie uzywam ]
In article <slrn.pl.ce0fdk.120.tomjas@perrun.ha1rtr.agh.edu.pl>, tomjas
<tomjas@WYTNIJTOpoczta.onet.pl> wrote:
> Hi!
> yellow--->MIC2
> black---->AGND
> front panel.
> Best regards.
Your computer case is missing the BLINE_OUT_R and BLINE_OUT_L. The
jack on the front of the case is supposed to return those two signals,
and they are routed to the Lineout jack on the back of the computer.
If nothing is connected to BLINE_OUT_R and BLINE_OUT_L, then there
will be no sound on the back jack.
As for the microphone, some sound control panels will offer options
for using one of two microphones. In other words, you have to select
which microphone to use. With the plug sensing built into some
sound chips, it may have switched over by itself.
http://www.xbitlabs.com/articles/multimedia/display/int-sound2_5.html
(I don't see an explicit enable for MIC2 in the mic preference panel,
unless "Standard Microphone" is the one on the back of the computer,
and "Headset" refers to MIC2 ?)
http://www.xbitlabs.com/images/multimedia/int-sound2/drv5.gif
http://www.fcenter.ru/articles.shtml?sounds/7678
(Perhaps the audio wizard can reset the microphone to the back ?)
http://www.fcenter.ru/img/article/sound/integrated_audiodecisions_2/32730.gif
General FAQ for Soundmax...
http://forms.analog.com/Form_Pages/soundMax/soundMaxSupportFAQ.html
If you aren't having any luck getting the microphone back, try
disconnecting MIC2 from the front panel wiring. Maybe the plug
sensing in the hardware is getting confused by your case wiring.
For example, if MIC2 was shorted to ground, maybe the software
continues to select the front microphone.
The hardware does support two microphones, as shown here on page 1:
http://www.analog.com/UploadedFiles/Data_Sheets/206585810AD1980_0.pdf
HTH,
Paul
W artykule <nospam-2806041335540001@192.168.1.177> Paul napisa³(a):
So is there any other solution? I have to add that each cable on the front
panel is divided into two at the end - so it is ended by two plugs, but
I suppose I cannot plug it into e.g. Line_out_r and BLINE_OUT_R
simultanously. So what can I do to make it work with this casing?
And what about 2 black ground cables - what do I need them for (is one
not enough)?
Exactly, I changed the source in control panel and mic works.
Thanks and regards.
tomjas
In article <slrn.pl.ce10sd.ksr.tomjas@perrun.ha1rtr.agh.edu.pl>, tomjas
> not enough)?
> Thanks and regards.
If your headphone jack wires are "Y" shaped, and each connection
has two ends, then, yes, you can connect them as shown here:
Front Jack Tip ------+--------< Line_Out_L
+--------> BLine_Out_L
Ring ------+--------< Line_Out_R
+--------> BLine_Out_R
Sleeve ---------------< Ground
What you cannot get from your computer case wiring, is a
mute function, when the headphones are plugged into the
front of the computer case. With the wiring shown above,
the headphones and the Lineout speaker connections will
both be operating at the same time, and there is the
possibility of some volume changes as you plug and
unplug loads from the headphone or the rear Lineout jacks.
This is what the wiring looks like when you use a proper
interrupting type headphone jack on the computer case.
Contacts 3 and 4 open, when a headphone is plugged in,
muting the sound on the Lineout jack. Your jack is
presumably missing contact 3 and 4.
----------| Sound |
| | Chip |
Case Front Audio | | -------------
("Interrupting" Type Jack) | |
-------- 1 AGND | | Lime Lineout (Back)
| ______ 2 Line_out_R <------| |
- -| / ^ | AGND ------+ (SLEEVE)
| | |--- 3 BLINE_OUT_R -------- | ----------+ (RING)
| | |--- 4 BLINE_OUT_L -------- | --------+ (TIP)
| | v |
- -| \_____ 5 Line_out_L <----------|
HTH,
Paul
