Archived from groups: alt.comp.periphs.mainboard.asus (
More info?)
Yes, I've checked the manual and do the installation exactly as it was
wroten. Still nothing. In BIOS there is no option to enable/disable Wi-Fi
slot. The Card was seated a couple of times to make sure that it was done
correctly. External antenna is connected all the time. And still the same -
no positive results
Any idea's ?
Greets
hose
U¿ytkownik "Paul" <nospam@needed.com> napisa³ w wiadomo¶ci
news:nospam-0901051848470001@192.168.1.177...
> In article <41e1a0ab@news.vogel.pl>, "n3lly" <djworen@WYTNIJklub.chip.pl>
> wrote:
>> Yes, I know about this issue and it's impossible to get a device in PCI 5
>> slot and Wi-fi at the same time .
>> But this isn't working - still my wifi card is not detected by install
>> manager.
>> Maybe I have wrong Bios settings or somethin'?
>> Greets
>> hose
> The manual is here, and when neither of the lights are lit on
> the card, the card has no power. I don't know what would account
> for that. It could be that the Wifi card is defective, or not
> fully seated.
http://www.asus.com.tw/pub/ASUS/mb/accessory/wifi-b/e1414_wifi-b.pdf
> Is the antenna connected ? Perhaps the unit is clever enough to
> detect no antenna ?
> The chipset comes from ralinktech.com , but there is nothing of
> any real interest on the site.
> Paul
>> news:nospam-0901051337120001@192.168.1.177...
>> > In article <41e13454$1@news.vogel.pl>, "hose"
>> > <hose@a.n.t.i.s.p.a.m.bestfilm.pl> wrote:
>> >> Hi,
>> >> I have 2-monthly asus a7v880 mainboard and I just buy a wifi-b/ralink
>> >> card
>> >> for my wi-fi slot on mainboard.
>> >> I plugged in into slot and switched on computer. When I try to install
>> >> a
>> >> message occurs "No item on this system". Wi-fi card LED's are not
>> >> blinkin',
>> >> bios is updated to the newest version, a wifi-b card is brand new and
>> >> so
>> >> are
>> >> drivers.
>> >> What's the solution - please help me. Why card isn't working? I've
>> >> tried
>> >> to
>> >> install drivers manually but when I try to run asus wi-fi control
>> >> center
>> >> the
>> >> same message occurs "no item on this system".
>> >> Greets,
>> >> Hose
>> > You cannot have a PCI card in slot 5 at the same time as the
>> > Wifi card. I don't even know if that is physically possible
>> > or not, but it is the only thing I can think of. The signals
>> > in PCI slot 5 and the Wifi card are one in the same, and
>> > cannot be shared.
>> > When buying wireless cards, you would be much better off buying
>> > a PCI card version of Wifi. That will allow you to move the
>> > card between computers when needed. The Asus proprietary
>> > connector is not good in this respect.
>> > Paul
