Archived from groups: alt.comp.periphs.mainboard.asus (More info?)
After hours and hours of troubleshooting and swapping out hardware
over and over again, I've been able to trace the source of a problem
in booting on this new motherboard to when any device is connected on
the secondary IDE channel. The system is a A64 3000+ CPU not
overclocked, and is non-Raid and non-SATA. All the BIOS settings
appear to be correct and this is about the 30th system I've built so
I'm not a newbie but can make mistakes just like anybody.
The problem occurs when the WinXP logo on the black screen first
appears, the video freezes, and then the system reboots. This can
happen two or three times in a row and then Windows will boot just
fine. Once Windows is running, the system is stable. Try to restart
Windows and the multiple attempts will happen all over again. Its not
a PSU issue as even that was swapped out with a known good PSU and
hardware monitor shows all voltages well within a 5% tolerance.
The strange thing is that the reboot or freeze always occurs at the
same point at the logo screen when Windows is loading so that tends to
make one believe that a driver is corrupt or a registry file or
setting is corrupt. However, disconnect all devices on the secondary
IDE channel and the system works perfect every time. So now I'm
stumped: is it a bad controller on the mobo or is it a Windows
problem?
Any ideas?
problem?
Any ideas?
