[SOLVED] Accidentally Broke CMOS Battery
AgentLoneStar007
Commendable
Jan 28, 2020
5
Hi. So basically here's what happened. A while back my mobo threw the code 00, which indicates a possible short-circuit. So I tried to remove the CMOS battery to let the power drain. When I went to remove it, I accidentally broke the spot it sits in. It's still there; it just hangs by a wire. I've noticed that every time I boot into Windows, I have to re-sync the clock, but this doesn't happen on Linux(I dual-boot). And I've also noticed that random BIOS settings might yeet themselves, such as trying to use WSL in Windows brings this output: "Please enable the Virtual Machine Platform Windows feature and ensure virtualization is enabled in the BIOS." I've already done that. I honestly don't mind having to reset the clock every time I boot into Windows, but I just want to be sure that it causes no harm to my PC. Would it harm my mobo? I use the Asus ROG Strix X570-E Gaming Motherboard.
Hi. So basically here's what happened. A while back my mobo threw the code 00, which indicates a possible short-circuit. So I tried to remove the CMOS battery to let the power drain. When I went to remove it, I accidentally broke the spot it sits in. It's still there; it just hangs by a wire. I've noticed that every time I boot into Windows, I have to re-sync the clock, but this doesn't happen on Linux(I dual-boot). And I've also noticed that random BIOS settings might yeet themselves, such as trying to use WSL in Windows brings this output: "Please enable the Virtual Machine Platform Windows feature and ensure virtualization is enabled in the BIOS." I've already done that. I honestly don't mind having to reset the clock every time...
If you have to reset the clock then the battery is most likely not connected through the broken battery holder.
You can have someone solder in a new holder, it's really not that hard. Running completely without a battery shouldn't be a problem though, but it will not retain any BIOS settings as you've found out with the RTC setting. If that's not an issue for you then continue as you are.
