Adding parts to a Dimension 8200
G
Guest
Guest
Archived from groups: alt.sys.pc-clone.dell (More info?)
Hello.
I am going to add some new parts to my 2½ years old Dell Dimension
8200, 2.0 Ghz, 256 MB Ram.
I am adding three parts:
First some new RDRAM 2x128 MB, so I'll have 512 MB. That will do a
lot, but I really could use more. Couldn't afford it though.
Next is a PCI to USB 2.0 Host Adapter (from Planet).
Last, there is the most important addition: a new graphics card.
Sapphire ATI Radeon 9600XT 128 MB. I know it's not the latest, but it
was cheap and will hopefully allow me to play Half-Life 2 decently.
My question is, what can I do to make it all work?
I have never tried to install anything in a computer before, and I am
hoping a friend with experience can help me.
I have the latest update of the BIOS, which AFAIK is the A09. But it
is pretty old. Is there anything I have to do about that?
Right now I have the NVidia GeForce 3 Ti200 card that came with the
computer. I know I should change my video driver to a default windows
driver before installation. Should I try to completely remove the
NVidia driver somehow?
Should I install everything at once or add one part at a time and turn
on the computer to let it detect it?
Any advice will be appreciated very much.
Thank you in advance
- Klaus Thomsen
Klaus Thomsen wrote:
> Hello.
> - Klaus Thomsen
My recomendation would ALWAYS be to add a bit at a time!! That way, if
there are any problems, it becomes easier to track them down.
Just one other point, when you put in the memory, you will find a couple
of Dummy Memory Cards already there! Don't worry about them, just remove
them!
HTH
Regards,
John
"John J. Burness" <JohnJBurnesAT@ieeDOT.orgNOSPAM> wrote in message
news:41b37c8e$0$52968$ed2619ec@ptn-nntp-reader03.plus.net...
> > Hello.
<snip>
I would agree with this. If you put all the new bits in at once, if any
problems show up it is more difficult to say which change caused it. I would
say do the upgrades one at a time. It won't take that long anyway.
"John Fryatt" <jrf1@ntlworld.com> wrote in message
news😛8Msd.297$_n5.290@newsfe2-win.ntli.net...
>> > Hello.
> <snip>
> would
1) Are you running Windows XP?
2) You'll be looking for PC800 45 or 40ns RDRAM in a matched pair
www.4allmemory.com
www.zipzoomfly.com
www.newegg.com
www.ebay.com
3) Install the software for the USB 2.0 card before physically installing
the card.
4) Regarding removing the Ti 200, you can simply remove it from device
manager (deleting it) and it should remove most traces of the NVidia driver.
Power down, physically install the new card...(yes your current power supply
should be sufficent). Windows will attempt to install drivers for the new
card at boot. You can cancel out the 'new hardware found' wizard and then
install the software for the new card, noting the path where the software is
installed/located. If running WinXP, you can go back into device
manager/display adapters/properties and use the "update driver" feature.
Point it towards the ATI folder.
I also agree that you should test each upgrade individually for a bit so as
not to get crossed up with any potential errors or problems.
Good luck and post back....
Stew
