D Dio64 Apr 4, 2019 1 0 10 Apr 4, 2019 #1 I am choosing a motherboard for my 9400f. I can't decide which one to buy from the two motherboards below. Asrock B365M Phantom Gaming 4 - AU$145 Asus TUF H370 Pro Gaming - AU$159 Any advice? Thanks in advance.
Barty1884 Retired Moderator Apr 16, 2015 22,254 1,355 108,740 Apr 4, 2019 #2 Almost all chipset boards (including Z390, AFAIK) will need a BIOS update to support the 9400F. Given that (assuming a local store will update for you), and it's a locked chip..... maybe look to some of the cheaper B360 boards? https://au.pcpartpicker.com/products/compare/JmF48d,6NgzK8/ Upvote 0 Downvote
tennis2 Glorious Nov 12, 2018 8,912 1,896 49,790 Apr 4, 2019 #3 The AsRock B365M will support the 9400F on any/all BIOS'. I'd go with that so you don't have to worry about the board not shipping with a BIOS that doesn't support your CPU. Reactions: ocer9999 Upvote 0 Downvote
