Hi, i've build a new PC, i will list components below.
After i built the PC it worked perfectly for 3 weeks, and then 2 days ago my monitor suddenly glitched for 1 sec and then got no signal. I tried every trick possible, different cables, slots, restarting, different monitor.. Issue is the same, no signal. I unpluged and repluged both RAMs and GPU separately and restarted. I tried the CMOS battery restet, both with GPU in MB and another time without the GPUusing the CPU/MB GPU with the monitor plugged in the MB and doing the CMOS reset. Didn't work. I did all this because i also noticed the DRAM LED is red and always on, and since i tried putting both RAMs in different slots, testing with one each time didn't work, i tried the Q-Flash plus trick by downloading from my old PC the latest BIOS file, adding it to the USB (yes i did everything acordingly, usb is 2.0, file name changed to GIGABYTE.bin, made sure the usb is MRB partition style etc.), with everything unplugged except power supply 24+8 pin cables, first time didn't work, so i had to first press the white button for resetting bios on the MB and then the Q-Flash button, then the MB seemed to do what it was supposed to, but eventually it also didn't work. Please help someone, i have no clue what else to do.
CPU is AMD Ryzen 7 7700X
RAM CORSAIR Vengeance - DDR5 - kit - 64 GB: 2 x 32 GB - 5200 MHz
GPU - MSI RTX4080 Gaming X Trio
MB Gigabyte B650 Aorus Elite AX
