Question After installing asrock polychrome my pc does not start
Tasobruheee
Commendable
Jul 7, 2020
30
Alright so. I got annoyed with the gpu rgb on my 6800xt phantom gaming gpu. so i found the software. downloaded it. and it wouldn’t start. what do you do when a program doesn’t start? restart your pc. and this is where i am. my pc does not start past the blue screen. i have the option to reset and all that but the thing is. i know my password but it says it’s incorrect. so maybe the internet isn’t working with it or something. anyways trying to boot into safe mode does the same thing. going into bios both my ssd and hdd were fine and connected. i made sure to disable xmp and all cpu over clocks. made sure everything was stock. but my gosh dang pc won’t start. please help. ☹️
Update your post to include full system hardware specs and OS information.
How are you trying to boot into Safe Mode?
If supported, try booting using the motherboard's integrated graphics.
This software?
https://www.asrock.com/microsite/PolychromeRGB/
Where did you get the Asrock Polychrome software? Are you sure that it came from Asrock's website?
Yes that software. Yes it came from the website. specs are as follows
r5 5600x
32gb 3200mhz corsair vengeance
480gb kingston ssd
2tb swag are barracuda
ds3h b550
hyper 212
750w gigabyte psu
I’m trying to boot into safe mode by doing this: it goes to blue screen, then after a few restarts it’ll give me a few options to try to recover so i do the restart to choose one of these options so i restart then choose safe mode and then it just blue screens again. Windows 10 btw
