It's ok. The confusion was cleared up.
What do you think about the situation of a 420 mm front-mounted when the case has a power supply shroud?
Wow, 420 is big for an AIO. I think 280mm is enough if the goal is just to use 140mm fans.
Plus, there's no need to have a fan blowing underneath the psu shroud anyway, since there's the option of setting the psu as bottom intake or top exhaust*.
[Some psus have a fan off mode, or are fanless. To take advantage of this, they should be flipped the other way, but not all cases have perforations in their psu shrouds, so beware.]
Look at how you use your PC, and monitor power use in your day-to-day activities. You can use HWINFO to see how much power your cpu and gpu use for tasks.
Unless you're running Blender or similar on an i9(or heavily OCed i7) for a few or more hours straight, the gpu often is the primary heating element of the space heater that is the PC, and they do so easily.
Plus with newer gpus only looking to get more power hungry... yikes.
[rant]
I swear society started this top cpu AIO mess.
Yes, a little warm air comes out the back of a front cpu AIO - it's overblown in most user's situations - it's still supplying air to the components behind it, and that's better than no air.
What about the open air gpus that dump their waste heat inside PCs, heating up components around and above them? Still overblown for most, but they are using more total power, and thus can heat up components more.
A front cpu AIO warms up components 1-2C more. An open air gpu can warm up components 4C or more, because they're drawing more, there's more energy leakage, that energy becomes heat, and heat has to go somewhere...
You look at how some upper end RTX 30 series can do some 400w of power with ease, and cpus like the 5800X and 12700K are doing like 120w - talking in game power use here - that's a gap of more than 3x.
Tip: If you do top cpu AIO, leave the rear fan slot empty, and put a filter over it. The rear exhaust alongside a top AIO is outdated(?) method. That just takes away a 2nd cool air source that could serve the other half of the AIO.
If you believed the front intake alone fed the entire AIO, you'd be wrong...
With tower air coolers, yeah, leave the rear exhaust fan where it is.
Look at it another way - if we ignore everything else, except the cpu and gpu:
"Front cpu AIO warming up the gpu isn't cool, but the gpu warming up the top cpu AIO is"...
That's what I see on tech forums most of the time. The whole argument should be situational depending on your hardware and how you use your PC.
[/rant]
What is your case? Case design will have an effect on overall cooling.
Also, more fans or stronger fans isn't always more better:
