Hi I have built my new pc and everything is working fine except there is no power in aio pump and radiator fans. The cooler is Asus ryujin 360 ii and the motherboard is Asus rog Z690 formula. A fan hub is included with the cooler. When I attach the case fans to the fan hub they are working fine. But when I attach the radiator fans and the aio pump to that hub, nothing works. I tried to plug the radiator fans to the motherboard fan header and they are working fine. I can manage this by plugging the radiator fans into the motherboard and the case fans to the fan hub. But the problem is that aio pump has two cables, one cable is plugged into aio pump header on motherboard and the other cable is micro usb which can only be plugged into the fan hub and the fan hub is not powering the aio pump. Sata cable is also connected to the fan hub but still no power. The fan hub is only working with case fans. Please help.
