I'm going to get either a 360mm aio for my CPU and mount it in the "side"/front of the lian li pc011 dynamic, or a 240mm aio for the CPU and then a 120mm hybrid all for my evga rtx 2080...
Question is, if I do the 240 aio for the CPU, and the 120mm aio for the GPU, can they be both mounted in the "side"/front? If they can, is it ok to mount an aio "upside down" (the tubes in/out going into the radiator being at the bottom)?
