[SOLVED] AIO Water cooling power supply
Peter_249
24
Do AIO water cooling systems require connection to the Power Supply, or do they get their power from the motherboard?
My motherboard is the ASUS Z590-PLUS TUF GAMING WIFI
I think by referring to the manual I can just connect one to both the CPU_FAN and the CPU_OPT FAN?
And also the AIO_PUMP?
D
Depends on the AIO some require sata power from the power supply while others require the pump to be hooked into well in your case the pump header and the fans to cpu fan.
