[SOLVED] AIO Watercooling - Is this sound normal ?
Feb 5, 2020
Hello,
I have builted my new personnal computer. Everything working fine but i have a weird sound coming from the watercooling that's harrassing me. It appears randomly and it's loud.
My cooler is an Artic Liquid Freezer II 280.
You can hear the sound here:
View: https://youtu.be/Qh6qvae0tjA
I can not even describe what that sound could be
Is it normal ? Can i "repaired" it ? ? Should i resend for replacement.
Thank you
That sounds like a fan thats hitting its sides on something. Have you verified its coming from the pump or radiator area?
Check all the fans to make sure they are not wobbling or hitting against the sides. Make sure nothing, like wires, is close enough to get hit by the fan blades.
