Iqbal_ :
Hi guys..Ive been searching all over internet for this but no specific answer..If you guys know please tell me..The question is..What kind of air compressor can i use to clean my pc?I know there is canned air and DataVac...Why would I spend money for air lol?JK..Just want to know if there is another way to clean the pc..Maybe Car Tire Compressor??Bicycle Tire pump?Can it be used?Thanks
Generally a shop compressor with a tank on it is the kind of compressor you'd use. If you know someone with a wood or machine shop, or you own a compressor you can use that. A bicycle pump dosen't really have enough pressure and would be a lot of work. "Canned air" products do not actually contain air, they contain diflouroethane, which boils into a gas at room temperature similar to how propane is a liquid while inside it's tank but a gas in the hose. Yeah, gas dusters / canned air are a bit expensive in some stores, but they do work very well and last a decent amount of time. You can maybe expect about 3 cleaning sessions of a few minutes each per can if you have a lot of dust to blast out. A vacuum cleaner with the small cleaning attachment or a handheld vacuum is another option, but you have to make sure you don't accidentally pull anything off (small cables, jumpers, etc) with that. I use either.
