Archived from groups: alt.comp.periphs.videocards.ati (
More info?)
"Paul Murphy" <p_murphynothanks@tospamhotmail.com> wrote in message
news:4203ea84$0$74277$ed2619ec@ptn-nntp-reader03.plus.net...
> "R. J. Salvi" <rjsalvi@nospamambianceacoustics.com> wrote in message
> news:3YNMd.7276$e11.5205@twister.socal.rr.com...
>> news:42031ffd$0$71968$ed2e19e4@ptn-nntp-reader04.plus.net...
>>> news:heiMd.7166$e11.5850@twister.socal.rr.com...
>>>> "CipheR" <cipher@nowhere.com> wrote in message
>>>> news:vl7301prfgh9elku26djedh8e07n2nps93@4ax.com...
>>>>> On Wed, 02 Feb 2005 15:09:13 GMT, "R. J. Salvi"
>>>>> <rjsalvi@nospamambianceacoustics.com> wrote:
>>>>>>I had a strange thing happen when trying to install an ATI AIW 9700
>>>>>>Pro in a
>>>>>>Tyan S2460...after connecting the aux 12V connector (floppy power
>>>>>>connector)
>>>>>>to the card, when I power the unit up, everything lights up/spins for
>>>>>>a
>>>>>>second, then dies. With a Radeon 9000 Pro it boots fine.
>>>>>>Mobo: Tyan S2460
>>>>>>BIOS: 1.04 (set so VGA does not use an IRQ)
>>>>>>PSU: Antec 550W
>>>>>>PCI cards in 5 of the slots (sound, USB 2.0, TV, NIC, controller card)
>>>>>>Dual 2600+ MP Bartons (266MHz FSB)
>>>>>>120GB HD
>>>>>>1GB (2 x 512) DDR266 (registered)
>>>>>>I haven't spent much time troubleshooting the unit yet, but I'm
>>>>>>curious if
>>>>>>anyone has had a similar issue and what the workaround was. OR, is
>>>>>>there
>>>>>>something obvious you see from my hardware config that I'm missing
>>>>>>(IRQ
>>>>>>problem, etc). Thx.
>>>>> I would try that 9700 Pro in a different system if possible, sounds
>>>>> like you have gotten ahold of a bad one... That PSU should obviously
>>>>> be more than enough, and Antec makes some of the best on the market.
>>>> My feelings too regarding the PSU. And yes, the card works fine in
>>>> another system.
>>>> It was suggested to me by a fellow in the Tyan newsgroup that I might
>>>> try using a 12V connector that has nothing else connected to it except
>>>> the AIW. Sounds like a possibility. Thx.
>>> Not only should you try that but the S2460 BIOS must be set to allow the
>>> VGA card to have its own IRQ. Both the S2460 and the AIW 9700 Pro are
>>> very power hungry on the +5 Volt rail (even though a floppy type
>>> connector is used on the 9700 Pro which also supplies 12 volts). I note
>>> that you list a TV Card as well as the AIW - there may be issues using
>>> both at the same time unless the TV Card is an ATI one and you are using
>>> MulTView (a function within ATIs MMC software). There's a newer BIOS
>>> version for the S2460 - 1.05, It would be worth updating to it (if
>>> necessary with the 9000 Pro installed).
>>> Paul
>>> Mobo: Tyan S2460
>>> BIOS: 1.05 (set so VGA does use an IRQ - essential)
>>> ATI AIW 8500DV (with firewire enabled)
>>> PSU: Tagan 480 Watt
>>> PCI cards in 3 of the slots (sound, NIC, 3Ware RAID controller card)
>>> Dual 1600+ MP Palominos (266MHz FSB)
>>> 4 x Samsung 120GB HDDs in RAID 10 configuration
>>> NEC ND-2510 DVD Burner
>>> Iomega ATAPI 250 MB Zip Drive
>>> 1GB (2 x 512) DDR266 (ECC registered)
>> Interesting regarding IRQ assignments for VGA. I originally installed a
>> Radeon 9000 (and a TV card which will be uninstalled with the AIW) with
>> no IRQ for VGA and it worked fine. My reasoning behind diabling the VGA
>> IRQ assignment was that I didn't want an IRQ conflict between VGA one of
>> the 5 filled PCI slots. I'll try it again with IRQ enabled for VGA.
>> On another note, it may very well be a power issue since I cannot even
>> POST. I'll try it again with nothing else connected between the PSU and
>> 12V aux. connection on the AIW.
>> Re: BIOS ver 1.05...I'm waiting for Tyan to send me a new chip. The one I
>> have in now is unsupported according to the phlash16 flash utility so
>> Tyan's sending me a new one.
>> Thanks for the info.
> Well it was a matter of luck if it worked with no errors while the BIOS
> wasn't assigning an IRQ to the VGA card - perhaps there's something unique
> about the Radeon 9000. I've read of AIW users having absolutely no luck
> getting cards to work until an IRQ is assigned to VGA in the BIOS and ATIs
> instructions state an IRQ should be assigned. Since you won't be using the
> TV Card with the AIW, you can leave the PCI slot free that has an IRQ
> shared with the AGP slot - cant remember which one it is but it's all
> explained in the motherboard manual.
It sounds like I got lucky. ;-)
> It may well be a power issue (either a dying PSU or possibly ATX connector
> meltdown as per here: http://students.washington.edu/vladis/atx_burn/ )
> I've had ATX connector meltdown occur on 2 separate S2460 boards (my
> original board and its warranty replacement, I'm on the third board now
> and so far so good - but that problem is very common with certain PSUs and
> the S2460). It would be well worth checking the board for any signs of ATX
> connector burning/discolouration at regular intervals.
Brand new Antec True550 and no ATX connector discoloration. The board
revision is the latest and I've gone so far as to augment the 5V rail with
the "molex tweak"
http://forums.2cpu.com/showthread.php?s=&threadid=28746
> The best bet if there's no sign of discolouration would be to run the
> machine with just the 9700 Pro installed and all the PCI cards removed (so
> the machine is as lightly loaded as possible and so you have the best
> chance of posting) and then measure the different voltages on the
> motherboard. The simplest way to get approximate readings of these is
> using Tyan's monitor software downloadable from their website.
Sound advice. With the 9000, the 5V rail was either 5.01 or 5.06V (can't
remember). That's good news...
Robert J. Salvi, Ambiance Acoustics
http://www.ambianceacoustics.com
San Diego, CA USA
(858) 485-7514
