Alphacool Eisblock GPX-A Review: Radeon RX Vega Gets Water-Cooled
@Alphacool ... please make an equivalent to the NZXT G12 adapter for upcoming GPUs, so i can use dual/separate/matching Eisbaer 360mm units in my Core X9 roof! i don't want to use an Asetek unit that can't be rebuilt/refilled/fixed, but i also don't want an expensive full block that won't fit on other cards in the future.
Why a chiller ? Why didn't you test with a typical water cooling loop which is what most people will be using ? With 4 or 5 other water blocks available why aren't you comparing this to any of them ? Is this the best one ? worst ? I dunno
Why bother why not buy a Nvidia 1080 air cooled have better performance and not bother with the faff of water cooling. I get it if you buy a top card and want more performance but why buy a cheaper card than spend more on water cooling it's not logical.
