Ok, I have had 2 separate PC harddrives that appear to have died in the past couple weeks and now I can't even reformat my nwer PC because of weird issues. I am a noob so please be patient here.
One of the harddrives that died was on a very old PC.. so I don't know if it was just a coincidence. But I have reason to suspect someone on a messageboard may have hacked me or sent me some kind of malicious malware somehow -- I have been getting harassed by some bullies on a website.
So on my newer Windows Vista PC I have 2 large harddrives. This PC is a HP Media center PC -- M8300F.
http://www.retrevo.com/search?q=HP+M8300F&rt=sp
The first issue I had on the PC was on the auxialliary drive. It started running really slow and my PC would freeze. The Aux harddrive also wasn't being recognized by my PC.. the autoplay thing would come up and ask me what to do with the drive.
So I managed to try to get as much info off it I could by removing it and using a USB adapter I have to make it a USB drive.
The main harddrive and my PC seemed to be working better then.
So I got everything off the main drive and reinstalled windows using recovery disks. Was working good for a couple weeks. But now there is a new issue.
I had rebooted my PC and it froze after I logged on to the Administrator account. I tried to use a previous restore point thinking that maybe a Windows update caused this... when I rebooted I noticed that my PC was installing a driver for my harddrive for some reason???
But my PC still kept freezing up after logging in and the programs loading. I tried to disable all programs on startup, too. So I tried to reformat but this didn't work.. after reformatting and reinstalling Windows it was freezing after the screen, "please wait while Windows prepares to start for the first time."
I ran Dban and wiped the drive and the same thing is happening.. I did get this message a couple times while trying to install windows --
Now it is freezing even before the recovery disks installs my factory programs...
So am I being hacked and that is why all this crasy stuff is happening? Or is it just a coincidence and this is all just old PC issues hitting at once?
My hunch from talking to someone and reading around is that it could be my RAM.. but I am trying to figure the best way to check that....
OR someone hacked me or got me to accidentally download some malicious software on a messageboard and it ran my harddrive till they failed and or messed up my BIOS or something like that.. if that is the case can I fix one of my harddrives and my BIOS?
Problem detected -- Windows shutdown to prevent damage
Page fault in nonpaged area
Check new hardware
if continues disable remove new hardware
disable bios memory options - - caching, Shadowing
use safe mode to disable components
*** stop: 0x00000050 (0xFFFFFF86, 0x0000001, 0x8449DB35, 0x00000000)
