Here's the plan; to overclock an i7 5960x to a stable, cool, 24/7/365 4.8-4.9 Ghz (definitely want over 4.7)
Here's all the hardware going in the build:
i7 5960x
ASUS RAMPAGE V EXTREME/U3.1 LGA 2011-v3 Intel X99
Corsair Dominator Platinum Series 32GB DDR4 DRAM 2800MHz C16 4x8Gb kit
EVGA GeForce GTX 980 Ti ACX SC+ ACX 2.0+ Graphics Card with Backplate 06G-P4-4995-KR
Creative Sound Blaster ZxR PCIe Sound Card
Intel Solid-State Drive 750 Series SSDPEDMW400G4R5 400GB PCI-Express 3.0 MLC
2x1TB Samsung 850 Pro SSD
2x1TB WD HDD
2x2TB WD HDD
EVGA SuperNOVA 1000 P2 80PLUS Platinum Certified ATX12V/EPS12V Active PFC 1000W PSU
Now here's my planned cooling:
Obsidian 900D ATX Super Tower Case
2x480 mm rads (I started a different thread about which is better, either Black Ice Nemesis 480GTX or Alphacool NexXxoS Monsta 480)
Twin D5 Pump XSPC reservoir
In a single loop through a EK-FB ASUS R5E Monoblock
8x Delta AFB1212GHE-CF00 120x38mm Grand High Speed Fans, @29 watts 240 CFM @ 29 mmH20 pressure,
Run on a Lamptron CF525 60W - 5 Channel controller. (It seems some don't recognize this controller so let me add a footnote; this is NOT a 60W controller, it's 300W with 60W on each channel having 3 molex plugs that recommends a 700 Watt PSU or better)
2x Delta AFB1212GHE-CF00 120x38mm Grand High Speed Fans on the front of the case
With finally w/e 3-5 watt fan I can slap on the back, also blowing in to try and have at least reasonable pressure going in the case (Probably a Noctua Industrial)
Footnote 2- before anyone says anything about jet engines and loud fans, I've lost most of my hearing, it would actually literally have to be a jet engine for me to hear it.
Finally, I know these CPUs are very easily taken up to 4.5-4.6 on decent 240-280mm rads with good ventilation on them, I've also seen them taken up around low to mid 5's on Phase Change cases or Water Chillers. From what I've read and a little from what I've seen, up around 4.7+ it starts getting much hotter than 280 or 360mm rads can handle. My biggest question is, am I going overboard with these fans? That's 300 watts just to the fans with close to 2000 CFM being moved through 2 massive 480mm rads. Is that overkill, should I just go with decent 3-5 watt fans or am I doing the right thing for my planned 4.8-4.9 OC. I would also like to add that I do a lot of video encoding so this CPU is going to be maxed out for hours at a time, often.
i7 5960x
2x1TB WD HDD
2x2TB WD HDD
