So I'm recently new to PC building and built my first rig earlier this year. The other day I picked up a AMD-8350 Black Edition, 8 Cores, 32 nm, and at stock clocks. I had a Cooler Master D92 on my previous AMD-6300 (wanted a little extra horse power for some games coming up this year
😉). I installed it with some Arctic Silver 5 to hopefully keep it cool but I am unsure if this is the case. It was running VERY HOT, 55C at idle. So I decided to re-seat the heatsink and reapply thermal paste. (Cleaned off CPU and heatsink with 91% Isoproply alcohol.) I decided to try my last little bit of Arctic MX-2 to see if that helped. It brought my idle temps down to about 40-45C. Then I ran Battlefield: Hardline to see if my CPU was ok now, It was running at about 60% load. I am unsure if this is too hot or not. Should I RMA the chip or get my money back and put in my 6300 again?
Specs:
AMD-8350 @ 4.0Ghz (stock)
ASrock 990FX Killer Fatality Mobo
Cooler Master D92 heatsink (With stock fans)
XFX AMD R9 280X (stock)
Corsair Force LS SSD 240GB
WD Black 1TB HDD
ASUS Wireless PCIE Wireless Card
Corsair Spec-01 Case
Arctic MX-2 Thermal Paste
Corsair 750 Bronze 80+ certified power supply
3 Corsair Case fans (1 that came with case, 2x are 120SP Red LED. Setup in 2 Intake front mounted fans and a rear exhaust fan.)
Windows 10 64-Bit
Temps:
http://imgur.com/gallery/lSsja/new
Specs:
WD Black 1TB HDD
Windows 10 64-Bit
Temps:
