AMD-A8 Cooler and Power supply Recommendations
excalibur5
5
Hello all, hoping I can get a good recommendation from the "Hive Mind".
I am upgrading my existing HTPC with a new motherboard/processor/RAM.
I just purchased this setup
http://www.amazon.com/GIGABYTE-GA-A75M-UD2H-AMD-A8-3850-Bundle/dp/B005AY5QHI/ref=sr_1_2?s=electronics&ie=UTF8&qid=1311123739&sr=1-2
It is a AMD A8-3850 processor and a gigabyte A75M-UD2H motherboard. I purchased 4 gigs (2 sticks) of DDR3-1600 ram to go with it.
First question: In a HTPC setup, the processor doesn't work all that hard the majority of the time. Does anyone have any opinions on the stock cooler? I don't want to be able to hear it when sitting 5' away. If you think I should upgrade the cooler, what should I get? Height isn't a problem in my case. Price is. I want it to run quietly (near silent - ideally the hard drives will be the things you hear.)
Second question: is my 380W existing power supply powerful enough? I will be running the above setup with 1 DVD-RW; and 2 7200 RPM Hard Dries (WD Caviar Blue and WD Caviar Black). I will be using the onboard video and one TV-Tuner Card.
