Hello,
I would like to know if anyone knows what the footnote means on the AMD website where it says that the max memory speed for the 8150 is 1866 but with a footnote reading exactly this, "1866 supported with 1 DPC (DIMM per Channel) in single memory slot motherboard designs." I would like to know if I would purchase two 8 gb dual channel kits to make 16gb total, would it be ok to have the four dimms each in their own slot running at 1866 dual channel. If not what is the highest speed I can have in the aformentioned configuration. I would really appreciate clarity on this.
Thank You
Here is my motherboard model in case it is needed - Gigabyte - GA-990FXA-UD3 (rev. 1.0)
Thank You
