AMD fx6300 running full speed
MartK
43
Hi
My problem is that my fx 6300 is running always at full speed. Any programs that automatically reduce the speed when necessary?
Hi thanks for the reply.
cool n quiet is enabled. still no luck. windows power plan is set to balanced. do i have to install cool n quiet dirver too? last time when i installed it it didnt work and said "this procsessor is not supported".
But when i put windows 7 power plan to power saver it reduces the speed.
but its fishy because its says "power saver". does it mean that when i play games then it still goes to full power when necessary?
overall cpu usage is 25-45% and the most demanding process is avastsvc.exe using 10-15 cpu.
[/URL][/img]
ok trying to uninstall avast! and install avg.
or can u give me some advice of a good anti virus program?
no nothing. at least i cant find something. only ccc and in chorme there are spotify where im listening music.
Yes every single core is at full speed. (3800 mhz)
that's the same info that i get from cpu-z
voltage is 1,3 V
(when i set to balanced)
Ok.
Go to power options from the control panel.
Then click on change plant settings under the 'balanced' option.
Then click on change advanced power settings.
Scroll down to processor power management.
Click on the + and go to minimum processor state.
Click on the + and see what it's set to. You can change it to as low as 1%
i have tried it before. it wont change. i think i just change to power saver when i watch a film or surf the web but when i play games then set it to balanced or high
i have asus m5a78l-m usb3 and bios version is 2001. i dont think that it needs a bios update because it worked fine about month ago.
i dont know when exactly when it happened but i recently updated amd chipset and video card drivers to omega drivers.
yes ccleaner is installed. but no oc programs and i havent oc my cpu or gpu. control panel? u mean device manager if so there isn't any question marks or exclamation marks. Trend-Micro-HijackThis nothing marked red/yellow.
