AMD fx6300 running full speed
MartK
43
Hi
My problem is that my fx 6300 is running always at full speed. Any programs that automatically reduce the speed when necessary?
thanks all for the help but i dont have time to mess with this. i hoped its a simple solution. when tpb comes up then i do a fresh download.
really? ether u are stupid or something else. it worked before. thanks for nothing. do u really think that when i have100€ ill spend it on a windows that i can just pirate or buy a ssd or something else?....
Thanks alot that u had time to help me but all of these tips wont seem to work. i have searched the internet too but nothing. yes i would buy windows 7 or 8 if it is 20€ on sale.
again thanks for the help and time. if u find something u can post but i think that its hopless.
(PS. only thing that i can remember that i have change is ide to ahci in bios and yes i think i did all correct) i followed this page:
http://www.askvg.com/how-to-change-sata-hard-disk-mode-from-ide-to-ahci-raid-in-bios-after-installing-windows/
and sorry that i was rude to you. :)
Changing the mode of the hard disk, usually means windows does not boot up at all anymore. These steps allow the boot to take place anyway and windows to work, but, it has to swap out drivers and so on, and things can go wrong there. So I suspect this is the reason.
I wonder why you changed the mode... It's not like you'll have much benefit, but oh well. Probably the only way to fix it is a fresh windows install. You can try reverting back, but I doubt that will fix it.
when i buy a ssd then i to a fresh windows 8.1 install. thanks all. this thread is closed 😀
