BGA only
There's no way it will go into an AM5 socket when it has a 256-bit memory bus. That would require more pins.
Although I wouldn't be surprised if someone hacks it onto a socket near the end of its life cycle.
256 LPDDR5 means 8x 32-bit LPDDR5 channels or 4x 64-bit DDR5 channels: no idea how costly it is to support both in terms of IP block size.
Four LPDDR5 channels could be serviced via on-package dies, leaving four to go off socket to CAMM or even to two DDR5 DIMMs.
That's not so far from an Alder-Lake notebook I run, which has one channel soldered with 8GB and the other using 32GB in SO-DIMM socket, which isn't perfect but much better at running multiple VMs with 40GB while the most bandwidth hungry part of the SoC, the iGPU is serviced from the bottom part of the physical RAM using both channels.
While bandwidth is absolutely crucial for GPUs, on CPUs access patterns are typically so chaotic, that caches do the job better than ultra wide RAM (not counting LLMs).
Now, of course, there is a non-trivial real-estate issue on AM5: that new SuperGPU IOD is bound to be huge, no matter what they use to fab it, because there is tons of I/O that's really hard to squeeze and plenty of SRAM within the GPU which isn't easy either. And that's before adding on-packge DRAM.
But if you go wild and into another layer, like the notebook SoCs being fitted to desktop sockets via an organic die carrier, things could be done in such a manner, that only half of the channels go through the socket, enabling an AM5 form factor.
But realistically such desperate measures seem unlikely, because the balance between that extra effort and just having Strix Halo APU soldered to a mainboard is too little value in a niche within a niche.
However, mainboards with such an asymmetric design, where 50% RAM in soldered LPDDR5 and 50% ready for upgrades as CAMM or DDR5 SO-DIMMs may perhaps not be that far off,
if the memory controller on the Strix Halo IOD actually supports that; or at least I hope so, because I tend to want far more RAM than mainstream hardware provides.
