I have the Following Setup :
Issue
I am experiencing high Temperatures at idle , usually around 65 and reaches easily 91 when on load. It has never gone above 93 even on stress for 30 minutes.
Note 1: I have applied Thermal Paste twice. That is certainly not the issue. I had the same exact Temperatures on the first application and when i opened it to apply the second time , there was no issue with the application. The thermal paste was on spot and the Heat Sink solidly attached to its base.
Note 2: I noticed that the Fan Speed is at 45% even while the CPU is reaching 90+ Celsius.
Note 3: No changes in Temperatures if i have the Lids open or not.
Resources
These are two screenshots from my Bios Software displaying the Version and the Fan Control. I have not activated anything. I have left everything in BIOS on default regarding OC and generally performance.
Here is a Screenshot in sequence while running cinebench. I have attached the Start , at 4 Minute mark and at 10 minutes.
Any ideas on how to solve this issue?
- CPU : AMD Ryzen 5 5600X
- Cooler : Stock
- Motherboard : MPG B550 Gaming Plus (MS-7C56)
- BIOS Firmware : E7C56AMS.1D0 ( 2023-04-28 )
- Room Temperature : 24 Celsius / 75.2 Fahrenheit
- Case : Coolermaster Cosmos 1000
Issue
Resources
