Question AMD Ryzen 9 3900x Power Plan Setting Help
chaos_viper15
171
So I was reading a article today that I realized I didn't have any AMD power plan options so as of now I've updated AMD chipset drivers and my motherboards bios. Now I have 4.
I've done this; - .10 offset vcore, cause I've always had that since build. After reading this this is where I'm at.
https://www.guru3d.com/files-details/1usmus-custom-power-plan-for-ryzen-3000-download.html
I'm now using that power plan with these bios settings
Global C-state Control = Enabled
Power Supply Idle Control = Low Current Idle
CPPC = Enabled
CPPC Preferred Cores = Enabled
Oh right sorry question was is this okay to use? Without damage to CPU at all.
Trying to get the best performance I can out of this CPU. I'm not sure if the offset messes with the performance adjustments made or not though.
