Amd sapphire RX 580 nitro+ fans problem
Dec 8, 2018
Hello . I have gpu rx 580 nitro+ , and when im playing gams my tempertures are going to 70-75 degrees in some games not in all for ex in league of legends 45-55 degrees celsius. The problem is my gpu fans are off about all time in lol , and in other games thry turn on but at 900-1100 tpm wich mean 1-10% speed. Why my gpu dont want to be more cold and go with fan speed for ex like 30-50% . I installed new driver 19.1.2 and on last driver this problem was not existed with fans.
All GPUs these days have semi passive fans. That's generally @ or below 55-60C depending on the manufacturer. Your card also has a "target temp" which you'll find in wattMan within AMD Settings. That target temp is usually 75C since it isn't bad for a GPU. That keeps noise levels down as much as possible.
Also, 1000rpm is probably at least 25% fan speed (depending on the card).
