Omegaclawe :
Interestingly enough, the card uses less power AND performs better when undervolted... goes about 5% faster, runs a few degrees cooler, and uses less power when the maximum voltage is dropped down to around 1.1V... it wouldn't surprise me if the "fix" was to simply make that the default.
AMD cannot make that "the fix" unless it is confident that at least 95% of GPUs will work properly for the foreseeable future at the reduced voltage.
With AMD trying to make improved power efficiency a big deal in its RX480 pre-launch marketing campaign, I would be a little shocked if the RX480 launched with voltages cranked up higher than was actually necessary. Who's running engineering at AMD?!?
I hope AMD does not drop the ball as badly on Zen's launch.
