AMD Vision Engine Control Center will not open.
cnm221
19
I have spent hours researching fixes to this problem, and nothing helps. I have reinstalled drivers countless times to find that ccc still will not open. The drivers seem fine, but ccc just refuses to open.
So I tried opening MOM.exe in Task Manager... I see CCC.exe opening in task manager, but then it just disappears.
I also updated my .Net 4 with windows update, that did not help.
Any help would be greatly appreciated... Thank you.
Yep, uninstalled driver with AMD... then deleted in device manager... Rebooted into safe mode, did driver scanner. Rebooted again and then did registry cleaner in safe mode. Finally installed the driver to no avail.
I don't believe this is a recognition error... The driver is working fine, it is just that the Control Center will not open.
My card is a DIAMOND Viper Radeon HD 3850 512MB, Mobo is ASRock 890GX Pro3, operating system is W7 32-bit, Driver version is 11-8 Catalyst
I am also still looking for help after installing 11.8 drivers every time i try to start AMD control center mom.exe pop up in task manager and closes no-mater what i do i have disabled all the programs that might block it this is dumbest bug i seen from AMD, should of newer upgraded those drivers,,,, any1 got any solutions ( except redoing drivers running uninstaller driver sweepers or such other nonsense)
