A third GeForce RTX 4090 owner reports that his 16-pin power adapter has suffered a meltdown.
Another GeForce RTX 4090 16-pin Adapter Bites The Dust : Read more
This is Incident Case #2 I believe?
Only if these reports are true. I'm not making any judgements for these particular cases , but it's a well known fact that people like to make <Mod Edit> up, especially for fame and profit.Ok, this is now beyond a joke, and actually scary...
Pci-sig also making this up?Only if these reports are true. I'm not making any judgements for these particular cases , but it's a well known fact that people like to make <Mod Edit> up, especially for fame and profit.
If all it takes is a few seconds with a cigarette lighter, you bet there will be some fake reports for this sooner than later.
The GPU maybe not, but the adapters I agree. However, it's bad design to have that plug on the top of the GPU that goes straight up if you need 3.5 cm of clearance. This doesn't matter if it's a 4090 or a 4060. Nvidia might be okay if they ship out 90 degree adapters though.Ok, this is now beyond a joke, and actually scary.
These GPU are a fire hazard and need to be recalled.
At first it was one guy with melted cables, now it's several reports in a matter of days. And that's a lot considering how few 4090 are even out there yet.
At this point I would not even install a 4090 / 4080 (or any AMD graphics card with this plug), even if given for free.
These GPU are clearly using power beyond the limit of what is safe with current PSU and standards, and the adaptors to make it all work seem nothing more than a dangerous hackjob. Just a matter of time before one of those things cause a fire.
What bothers me is quite a thing was made about the viability of these new plugs before the release at it was not looking good.
This is what happens when the "bean counters" get involved in pure engineering decisions when they start asking "but if we make it cheaper, would it still work?".We discuss results of corporate greed. Maximum profit by all means. Including savings from investing the necessary materials in the products.
If needed? There's no if about it, it's clearly a safety issue. Nvidia need to fix this pronto and issue a recall, before somebody gets hurt in a fire.Nvidia will get to the bottom of the issue quickly and provide consumers with a solution if needed.
It has the same effect as far as heating the copper conductor, but the AC ripple should be small versus the slug of DC current the connector is seeing. There are several FEA packages available to simulate this, and I'm sure it was looked at.I wonder if DC has the same effect as AC for too thin wires
I bet they made it this way to make a backwards-capable path. Otherwise, they should consider a really thick, single cable with 1-2 wires instead.
I can see the 3.5 cm clearance being a huge reason why AMD didn't want to do it for their upcoming cards.
There are more, these are just the ones that have gone viral.This is Incident Case #2 I believe?
It'll be more than a few weeks before you'll find one in stock anyways.I WAS close to pulling the trigger on a RTX 4090 but this gives me pause. I might only upgrade my cpu platform and see how this shakes out over the next few weeks.
