another guy with Sidewinder ff Wheel's problems
G
Guest
Guest
Archived from groups: microsoft.public.windowsxp.hardware (More info?)
Thank you Joshua for reply and for registry key (i will remember it in
the future), but my PCI audio card is disabled and i use a Soundblaster
Live's gameport
'Joshua Smith [MSFT Wrote:
> I am not sure I understand what is wrong...
> [/i][/color]
I'm sorry for my english, but i had a bad teacher 😉
For example (in racing game of course) the force feedback pull ever on
left and the wheel never simulate crash.
The force feedback is wrong and i suppose it's a joystick ff not a
wheel ff 😕
Hi
> ']Hi Marione,
> I am not sure I understand what is wrong so I will just give you some
> information to work with and hope it covers it. :)
> The gameport force feedback devices can be messed up easily if there
> is
> more then one gameport in the system. Disabling an onboard gameport is
> usually sufficient to fix this. Some gameports are just not very good.
> Sometimes it is necessary to get a sound card by a reputable
> manufacturer. Remember to disable any existing onboard gameports if you
> add
> another one to the system.
> If you want to adjust the level of forces in Windows XP you have to
> use
> these instructions since the software that usually handles this
> doesn't
> operate on Win NT systems.
> Reducing device default force levels:
> There is a value that Dinput writes in the registry that keeps track
> of
> how hard the forces should be applied to a device. The range of values
> it
> takes is from 0 to 10000. If the driver has told Dinput to set the
> force
> level at the default (10000) then the registry key is deleted. This is
> why
> the key doesn't exist on your system.
> 1. Open the Registry editor
> 2. Navigate to the following key:
> HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\MediaResources\Joystick\Dinput.dll\CurrentJoystickSettings
> 3. In the right pane of the editor right click and create a new "DWORD
> value".
> 4. Make the name of the value Joystick##FFConfiguration, replacing the
> with the same number as seen in the Joystick#Configuration key. If you
> have
> more than one joystick device this can be tricky, but in your case it
> is
> almost sure to be 1. e.g. Joystick1FFConfiguration
> 5. Right Click the Joystick#FFConfiguration and choose Modify.
> 6. Set the value to something between 0 and 10000 Decimal. Depending on
> the
> device values lower than about 2500 may not be felt at all. 10000 is
> the
> default and represents 100% force strength. 5000 is probably a good
> point to
> start. That would be 50% strength.
> 7. Try your game to see if the force level is better for you. If so
> close
> the editor.
> Let me know if that didn't help.
> Joshua Smith
> OpenGL Test Lab
> Microsoft
> Get Secure! www.microsoft.com/security
> This posting is provided "AS IS" with no warranties, and confers no
> rights
> "marione" marione.1tnfpp@pcbanter.net wrote in message
> news:marione.1tnfpp@pcbanter.net...-
> Hi,
> I bought a microsoft sidewinder force feedback wheel (gameport
> version).
> It work fine under windows 98/ME.
> Now under XP it don't work fine.
> Windows XP recognize the wheel driver, but force feedback work wrong
> and i do to disable it.
> There is a mode to use force feedback in xp?
> Thanks
> marione-
marione
Hi Marione,
What game are you seeing this in? I don't know of any games in
particular that have issues like this, but maybe I can set up a system here
and see if I can see what you see. Can you also send me a dxdiag report of
your system?
DXDIAG:
1. Click Start -> Run
2. Type "dxdiag" without the quotes and press Ok.
3. In the DirectX Diagnostic tool click "Save All Information..."
If you have any questions or I didn't explain something well enough don't
hesitate to e-mail me (remove "online") back. Good Luck,
Joshua Smith
OpenGL Test Lab
Microsoft
This posting is provided "AS IS" with no warranties, and confers no rights
"marione" <marione.1tod1s@pcbanter.net> wrote in message
news:marione.1tod1s@pcbanter.net...
> Live's gameport
>> [/i][/color]
> wheel ff 😕
> Hi
>> ']Hi Marione,
>> is
>> add
>> use
>> doesn't
>> of
>> it
>> force
>> why
>> value".
>> have
>> is
>> the
>> the
>> point to
>> close
>> the editor.
>> Joshua Smith
>> OpenGL Test Lab
>> Microsoft
>> rights
>> Hi,
>> version).
>> Thanks
>> marione-
> marione
