The font is "lato" and doesn't show in my fonts.delete this font from windows
I got the font name using 2 browser addons. Both showed it was Lato. (Also looked in the page code.) I hadn't checked the registry which I just did. And the other locations tenforums talked about. No Lato anywhere.search on different locations
Delete and Uninstall Fonts in Windows 10
How to Delete and Uninstall Fonts in Windows 10www.tenforums.com
how did you get the font name?
easiest way would be something like
Font Finder - Microsoft Edge Addons
Make Microsoft Edge your own with extensions that help you personalize the browser and be more productive.microsoftedge.microsoft.com
or you can find it analyzing the code yourself on the pages which are wrongly displayed:
How to Check the Font Size & Face on a Website
With literally millions of fonts out there, finding that perfect one can take longer than it should. When you do spot a good one, you need to find outwww.alphr.com
Something is sure off... I checked Chromes AND Edge today and now they are showing a DIFFERENT font name, though it's the same ornate scripty font. I have no idea what's going on.please upload a screenshot of the analysed font , sounds like a special problem
I'm not too skilled that this, but here is a screenshot using the right click inspect on MS Edge. Not sure this is the area you need but it shows the font Anek which is lined out. I'll look at the windows integrity thing next. I appreciate you time and help on this.try without extension and only using the browsers tools to check the font.
chrome: right click -> inspect
I think Anek Bangla doesn´t look like the example you´ve given.
check windows integrity
open the command prompt as administrator and type DISM /Online /Cleanup-Image /RestoreHealth
https://www.lifewire.com/how-to-open-an-elevated-command-prompt-2618088
https://answers.microsoft.com/en-us...em-files/bc609315-da1f-4775-812c-695b60477a93
clean boot
How to perform a clean boot in Windows - Microsoft Support
Describes how to use the clean boot process to troubleshoot a problem in Windows 8.1, Windows 8, Windows 7, or Windows Vista.support.microsoft.com
