Archived from groups: comp.sys.hp.hardware (
More info?)
This is from an HP 5500 Officejet manual I downloaded a while back
when contemplating purchase of a 5510:
"How your HP Officejet will answer fax calls
"You set the HP Officejet to answer after 6 rings, and you set your
answering machine to answer after 4 or fewer rings. This ensures that
your answering machine will always answer before the HP Officejet.
"When the phone rings, your answering machine will answer after the
number of rings you have set, and then play your recorded greeting.
The HP Officejet monitors the call during this time, “listening” for
fax tones.
"If incoming fax tones are detected, the HP Officejet will emit fax
reception tones and receive the fax; if there are no fax tones, the HP
Officejet stops monitoring the line and your answering machine can
record a voice message."
I assume your 6110 is supposed to work the same way. It sounds like
you have it set up correctly. There is a difference between the two
RJ-11 jacks on the 5500. The one for the phone line input is labeled
"LINE" and the one to the answering machine is labeled "EXT". Swapping
those might cause a problem.
The only other item to consider is that the 5500 manual says to use
the included 2 wire phone patch cord between the wall plug and
printer/scanner/fax unit. It says specifically to not use an ordinary
4 wire patch cord.
I cannot explain why that should make any difference because the
normal single line phone connection is handled by only 2 wires anyway
(the two inner contacts on the RJ-11 plugs). They seem to be concerned
about possible crosstalk from a second phone line on the other two
wires (the outer two contacts on the RJ-11 plugs). But if that were
true, then a lot more coupling would already exist in the building
wiring where the four wires are bundled together.
Dick Ballard
ballardr@att.net
On Mon, 03 May 2004 19:50:49 +0200, rafafa
<rafafa90210nospam@yahoo.com> wrote:
>Hi all,
>I try to have my answering machine working with my new officejet 6110
>but no luck yet...
>The phone lines goes to the printer, a cable goes from the printer to
>the answering machine.
>The answering machine "answers" after 3 rings (the 6110 manual states
>that it should be less than 4) but if it's a fax I never get it.
>The 6110 then print a sheet with "error 283", "If you try to receive a
>fax, call the sender and tell him to fax again..."
>Any ideas would be appreciate,
>RG
