G
Guest
Guest
So as the title may suggest, I need some help choosing a cooler for my AMD Phenom II X6 1055T in my Antec 300 case. At the moment I have a NZXT Sentry 2 fan controller and have 4 120MM fans hooked to it, as well as the stock 140MM top fan. All my fans are tri-cools and generally I leave them on the medium settings and leave my fan controller at auto. My case ambient temp is usually about 80 F (23 C or so). I'm not complaining. But Uncle Sam just sent me a little cash for my tax refund and I wanted to put a little bit to use on my PC.
At the moment I plan on keeping the CPU at stock voltage (1.4V, per AMD's website) and I was a little pissed when I looked under "Normal" in my BIOS and I was getting 1.475V to my CPU (My motherboard is a GA-890GPA-UD3H Rev. 1, BIOS F7B) so I adjusted it accordingly. Also I did not use the stock thermal pad. I used Arctic Silver 5 (a good old standby. I know there are better but I had it on hand.) I also use Patriot DDR3 1600 gamer memory set to 7-7-7-20 @ 1.7885V. As par for the course with Patriot it needed a little extra juice to run stable (They say on their website that these memory modules can take 1.7-1.9V to be stable. )
Anyhow, I am currently running prime 95, stock with the stock heatsink and fans set to auto at 43 C on max heat. Not terrible, but I want to go lower without undervolting or water cooling so I began looking into the Noctua NH-D14. It seems OK but I have some concerns. Would one fit in my case with the type of memory I have (Gamer memory has heat fins)? I looked around at the mounting system doesn't seem to require you to remove the motherboard and install a secondary backplate. However it will require removing the stock plastic shroud (if thats the right term. The plastic bit that stock heatsink clamp onto.) and you will have to install 2 "C" looking clamps. Then it appears very straight forward. Although I imagine installing the center fan will be nightmarish once installed in the case.
Anyhow I haven't seen any review regarding performance of this particular heatsink on the hexa-core CPU's but it seems OK. I also admit to being a bit concerned with weight and it bending the motherboard with time. I've used the Coolermaster 212 Hyper+ and the Corsair H50 in the past on my i5 750 and both proved decent but I thought I would try for something that won't require me to remove the motherboard and get very nice and quiet results.
Also if anyone has any suggestions for alternate thermal paste or heatsinks I should look into, I would greatly appreciate being pointed in the right direction.
Thanks guys!
Thanks guys!
