The Switch Needs To Be Replaced. Is The Wire Harness Connected With The Reset Switch? Need To Disconnect From Motherboard? Is The Silicone What’s Holding the Switch In?
What do you intend to do? The wires are soldered onto the back of that switch. You might as well snip them off at the ends where the heatshrink terminates.
Contacted Antec and they replied
It is not silicone. It is glue. just remove the glue and power switch will come out.
The wire harness did not connect with reset switch Need to disconnect with MB
