Any way to fix red screen on Samsung monitor?
lttoler
4
I have a Samsung SyncMaster 204BW monitor and it has recently been giving me issues. The screen has a red tint over the entire screen. The adjustments quit working at the same time this problem occured. I have already ordered another monitor for my primary use but was wondering if there was anyway I could personally fix this monitor to use on another old computer. Could it be something simple that I just need to re-solder back?
Any advice or opinions would be greatly appreciated. Thanks in advance!
Your on display buttons are not working, right?
You can temporarily fix it by using windows display calibration. I'd say donot try to open the monitor yourself if you are not good with these things as you might end up breaking it.
