I'm looking to swap out my small case to a mini-itx mid-tower for better airflow. The problem being there are only 2 4 pin headers on my motherboard. So, I have to get a fan hub for 4 pin fans, no problem. But I'm trying to do this on a budget and most cases come with 3-pin fans. I can't use 3-pin fans with a hub, because I don't want them running at full rpm. So they're useless to me. I'm willing to pay just under $100 if that means I don't need to buy any extra fans but maybe one. I've been looking off and on for days! So if you have any suggestions that would be much appreciated thank you! If you have any alternative routes let me know as well
Update: I'm willing to use 3-pin fans if there is an easy way to manage the speeds so it's not always constant.
